Czy ktoś miał do czynienia z tą koncówką? Pochodzi ze Szwecji.
2 x 50 W w klasie A, potem już w klasie AB.
Na rynku wtórnym kosztuje ok. 2000 zł. Nie znam innej koncówki 2 x 50W w klasie A.
Dane techniczne:
A few key properties for AP-100:
* New circuit board layout
* Shielded design for each internal section
* All inputs and outputs are gold plated high quality units
* Symmetrical circuitry
* Balanced input
* Bridged mode option
More info >
Class A or Class AB
Class AP100 is constructed to let you select class A or class B mode. If you want to focus on lower power consumption, select class AB mode and if you want maximum sonic performance select class A.
Technical presentation
The amplifier is equipped to offer you top end performance. All inputs and outputs are gold plated high quality units. A powerful toroidal transformer guarantees an efficient power supply.
All sections are separately shielded to minimize cross hearing and interference. Twin differential input stages and fully symmetrical circuitry through the complete signal path ensures perfect performance. The differential circuitry helps suppress distorsion, especially the odd overtones. The output stage itself provides High End performance thanks to the use of fast bipolar transistors from Toshiba, which are also capable of very high output currents and handling tricky load impedances.
The cabinet
The new cabinet design, with its softer and smoother edges, is in all essential parts made from highly stable aluminum. This enhances the impression of quality and provides a rigid construction. Outer interference is effectively shielded, and the aluminum helps with heat dissipation, spreading it evenly through the amplifier.
Output power:
2x50W 8 Ohms (Class A)
2x110W 8 Ohms
2x180W 4 Ohms
2x350W 2 Ohms
Bridged mode
1x 370W 8 Ohms
1x 500W 4 Ohms
Technical Specifications:
Construction type: Class A possible to switch over to class AB
Size: 150 x 435 x 410 mm/460mm incl volume knob and speaker terminals (HxWxD)
Weight: 22 kg
Weight: 46 lbs
Technical info
Fully balanced low distorion circuit board design
Technical data
•Distortion: < 0.03% (20Hz to 20kHz, 10W)
•Input sensibility : 1.0Vrms
•Damping factor: > = 100
•Input impedance: 20 kohm
•4 output transistors per channel
•Toroidal transformer
Frequency range
5-50k Hz (non flatness < 0.5dB)
Colour
•Black/Silverwhite
•Silverwhite
•Black
Connections
•2 inputs XLR/RCA
•Gold-plated RCA connections
•Solid gold-plated loudspeaker connections for banana plugs, fork plugs and screw plug
Edytowane przez pmcomp
Zaraz Ci powiedzą że ze sprzętem za 2tys to nie do zakładki hiend :)))
A tak na poważnie to ciekawa jest, bardzo nawet...
co by nie mowic,2tys zl zaden pieniadz na eksperyment,a wyglada na solidna,zbalansowana koncowke.
jak nie zainstalujesz we wlasnym systemie,to odpowiedzi nie znajdziesz.
troche jest o niej na google.
Troche jest ale nic o dźwieku.
Liczę, że ktoś słuchał to w naszym kraju. No ... chyba, że za tania ? .
Tu znalazłem manual:
Jaka Szwecja :-))) Panie to jest 100% chińczyk, tak francuski jak Advance Acoustic albo 'niemiecki' Vincent.
Wygląda jak z fabryki AA albo Jungsona, patrząc po soldermasce.
Zobacz jak swietnie jest zbalansowany :)))))))))
Osobiście nie zaprzątałbym sobie tym głowy, chyba że za 300 maksimum. Moim zdaniem już lepiej pobawić się nowymi Hypexami z Audiophonics i do tego jakimś lampowym pre, może nawet vintage.
Edytowane przez Marek.S
hm,niewiele na chinczyka wskazuje,,,ale,,,
Ja tam widze w 100% chiński wytwór, nawet patrząc na ten selektor 120/230V. I jeszcze ta łamana angielszczyzna, tzw. "Engrish":
"Go standby automatically when no signal".
To jest chyba ta sama fabryka co Emotiva.
Za kwotę 500 EUR nie spodziewałem się nic innego niz Chińczyka.
BTW znalazłem gdzieś ostatnio Moon i-5 za ok. 1000 GBP. Znakomita integra ale ... tylko 5 prawdziwych A-klasowych watów ? .
E tam, klasa wzmacniacza nie gra, gra aplikacja. Krell nawet z klasy A potrafił zrobić żyletki.
Na JBLach, sekcji MF/HF te 5W starczy z palcem w nosie.
Jak chcesz coś ciepłego to poleciłbym raczej małego Pass'a.
2 godziny temu, Ivan Nikitin napisał:
Ile ciepła musi rozpraszać wzmacniacz 50W w klasie A? Czy jest możliwe zbudować taki bez wiatraków?
a jak myslisz?
Kwestia wielkości radiatorów.
Zobacz jak wyglądała seria Pass Aleph. Cała obudowa była radiatorem.
  • 11 miesięcy później...
W dniu 28.02.2020 o 20:14, tomek7776 napisał:
a jak myslisz?
W Plinius SA-50 (pasywny bez wentylatorów)  , 2x50W klasa A dla 8 Ohm , pobór z sieci ok.600-700W
i goracy jest jak .....reka nie dotkniesz. za dlugo
a to tylko 2x50W
Za samą obudowę tak wykonaną trzeba położyć minimum 1000.
W dniu 3.04.2020 o 15:54, Lyric napisał:
XTZ AP-100 brzmi ok, zalezy komu co podoba się.
Mam cały zestaw XTZ ,
ma neutralne brzmienie
,reszta zalezy od utworów muzycznych
A tak przy okazji jak masz tą końcówkę, jaką temperaturę osiągają pióra radiatorów?
A to ktoś zna:
r4E0Q9Rn2afO0eWQ7lCbekAMxFwXU10mTReJx6PJ
Jest do tego nawet preamp:
  • 9 miesięcy później...
Mam ten wzmacniacz od nowości jakieś 7 lat sterowany pre Vincent sa91 kable Audioquest xlr zwykły estradowy.Jest to solidna szwedzka myśl techniczna wyprodukowany w Chinach (a co nie jest ?).Cena/ jakość myślę bardzo dobra obudowa bez zastrzeżeń co prawda jeden kanał przestał działać po miesiącu ale na gwarancji naprawiony zimny lut.Od tego czasu zero problemów dobre elementy w środku pewnie cena wymusiła jakieś kompromisy ale zrobione z głową tam gdzie trzeba solidnie. Był to ich pierwszy wzmacniacz zanim jeszcze stali się znani w Skandynawii więc nadrobili jakość/cena,teraz mają parę kolumn i elementów kina domowego co wygrywa w swojej klasie cenowej z konkurencją więc chyba jakiś poziom mają. Dobrze radzi sobie z większością kolumn nawet wymagających świetnie oddaje scenę 3d średnica i wysokie petarda,bass jakby trochę brakowało pary ale u mnie to subby aktywne robiły robotę.Wydaje się że wzmacniacz nie dodaje dużo od siebie jest transparentny szczególnie z transparentnym pre jakim jest ten Vincent. Ciekawe jak by zagrał się z lampowym pre albo jakimś CD z buforem?  Wygrał w porównaniach z Denonami pma 1500R 800NE i 1600NE Onkyo Integra A 8170 Miusic angel MK3 kt88, Kenwood KA5090R,Sony f590ES,i jeszcze parę innych które się przewinęły przez ręce.Wiec to nie najgorsza opcja czy są lepsze?Pewnie że są . Ogólnie dźwięk to kwestia indywidualna najlepiej posłuchać z resztą komponentów.I wybrać na ucho. Oczywiście wiem że jest 2022 ale może komuś się to przyda poza tym mam kwarantanne.Pozdrawiam pasjonatów muzyki z elektroniki.
  • 1 rok później...
